AMD Radeon R9 Fury Review: Sapphire Tri-X Overclocked
  • Thread starter Thread starter Guest
  • Start date Start date
Serious question: does 4k on medium settings look better than 1080p on ultra for desktop-sized screens (say under 30")? These cards seem to hold a lot of promise for large 4k screens or eyefinity setups.
I was in microcenter the other day, one of the very few places you can actually see a 4K display physically. I have to say i wasn't impressed, everything looked small, it just looks like they shrunk the images on PC.
Maybe it was just that monitor but it did not look special to the point where i would spend $500 on monitor and $650 for a new GPU.
Wow, no wonder Nvidia released the 980ti. I was a bit surprised to see these benchmarks with the Fury cards beating up the 980 like they are. Nvidia really blew the wind out of AMD sails with their ti.
fyi - typos in verdict: should be "has proven" and "fewer texture units"
Very late night writing. I'm impressed that's all there was actually.
This is going to be relative to the game, and to the users perception. Medium settings will have lower quality shadows and lighting, both of which are not improved just be resolution alone.
Some games will look great, and most will likely play excellent, but do you really want to spend $550+ on a graphics card to play your games at medium?
4K can make up the difference of not using anti-aliasing, but it can't improve low quality visual features beyond making them look sharper.
Sounds like you only got to see the monitor in a Windows environment, and not a gaming perspective. Windows 8.1 doesn't scale 4K displays very well, making everything much smaller, sometimes to small to work with. Windows 7 is even worse.
Windows 10 is supposed to have better scaling for 4K displays, but I haven't personally had a chance to verify this so take that as you will.
I'd like to point out that before LCD screen were popular, 19- and 20-inch monitors used to have ridiculously high resultions that made everything tiny. This was the norm back then, and even saught after. It's only since the immergence of 4K screen that we've gone full circle in that regard. People are just used to larger icons and text now.
I hope you can add the 5.7 driver results.
Aside from the spot testing we mentioned, we did not get a chance to fully benchmark the card with that driver before the samples we both had were sent back. My sample was gone before the driver was even released. Igor only had a few hours with it at the time.
Future reviews will of course run the newer driver so we'll those tests for you as soon as we can.
Roughly: ultra settings define the quality of the content, while resolution defines your view of it. 4K just makes the picture sharper, if you currently notice no difference between 1080p with AA and 1080p without AA, then you won't notice much of a difference with 4K either. Personally I've always preferred a smaller resolution with better settings.
When the @#$@#$#$@#$@ are your web designers going to fix the bleeping arrows on the charts????!!!!!
"Has proved" is actually correct, but just in case I'm checking again with our copy chief. Good catch on the other, and you made me find another (it should be "door" singular rather than "doors" plural).
- Fritz Nelson, Editor-in-chief
I agree!!! Since this is part of a product widget in our system, it's actually a dev change rather than a pure design change. At some point, these went from being transparent to being opaque. We've asked for it to be changed back, and it is in the dev queue I am told. Still, comments like these help me coax these changes along.
Thank you! I keep having to remind myself that in the late '90s and into the early '00s, a portion of your readers were in grade school and weren't tech savvy back then to appreciate the changes we've experienced over the past 15 years. Circa 2000, your typical household PC (all 50% of the households who actually had one back then) had a 15-17" CRT monitor with a resolution of 1024x768 or 1280x1024 respectively. The high end monitors of the time were 19"-21" 1600x1200 resolution CRTs. It was huge jump going from 1280x1024 to 1600x1200 for the time, as minor a jump in resolution as that sounds today.
I agree as this has been my experience but I haven't yet had the opportunity to try gaming on a 4k setup yet. My personal preference would be 1080p ultra with high frame rates rather than 4k medium at 30fps.
Slapping on a standard tri-cooler onto this short board is effing dumb.
Considering the temperatures being reached with even this large of a cooler, I completely disagree with you there.
with a chip that generates this much heat you have 2 options. Loud fans that move a tonn of air, giant heatsink and quiet fans.
I think most people have a big enough case that the size doens't make much difference, and would rather have quiet operation.
There will likely be options from other vendors that go the oposite direction.
This was a pretty lame bogus review. I did a side by side window comparison with the factory overclocked reviews of all cards from the June 18 AMD R9 390x and the results didn't come close to matching up. This was evidently done at very low resolutions and while it appears the non-Fury cards were not run at the factory overclocked settings; while the Fury was overclocked.
You did a great review of the MSI 390x vs the MSI 980x factory overclocked at the ultra game settings in June, but really dropped the ball here. Except for major changes to your standard computer setup (ie new mb, cpu ram on an annual basis), driver updates and the inclusion of occasional new games; we should be able to compare previous testing results for cards on your standard bench system to the newest reviews realizing that only drivers may be different.
When you drastically change your testing methodology it really brings into question your motivations. Personally the June review nailed it with ultra game settings and the factory overclocked card settings for all cards telling me what relative performance to expect if I bring a high end card home and run it on my system and monitor resolution. You don't have to be a computer overclock guru to move game setting to ultra and click the factory overclock setting on high level cards at home and receive similar results.
