Z Zephyl Commendable Mar 13, 2017 377 52 1,740 Mar 17, 2017 #1 When I open AMD Radeon settings, all that appears is a blank window with the W7 Aero effect (Glass) on it. Any fixes?
Solution laviniuc Mar 17, 2017 you could try to reinstall? if you do a clean reinstall that will reset the settings.
laviniuc Judicious Nov 29, 2013 5,505 18 32,415 Mar 17, 2017 Solution #2 you could try to reinstall? if you do a clean reinstall that will reset the settings. Upvote 0 Downvote Solution
