AMD ReLive HELP PLEASE!!!!! Audio Sync Trouble
TitanWulf
33
Im having trouble with the AMD ReLive feature. The video quality is amazing and I dont see any fps hit while gaming, which is great! the problem is that all my recordings end up with a bit of desync.. sometimes not straight away but in 100% of them, it has about a 1-3 second desync which is really diong my head in, ive tried alot of different settings but nothings helped.. !
Can some AMD Super genius please shed some light on the situation!
Hm... Never really tried it before but if you have XBOX DVR enabled, please disable it because it has known errors associated with recording if it's enabled and not in use.
Also, ReLive experiences lag and such when using Alt+Tab while recording, so have you done that during recording anytime?
Thanks for the reply! Ill try turning off XBOX DVR and see how I go!
As for alt tabbing i know there have been situations where i havent alt tabbed and it has still had audio desync so i dont think that is it
