EDIT: I replaced the PSU and that did not fix the problem. I replaced the GPU, and the new GPU works. I am going to keep the PSU, since I feel it is always good to have a backup. Strange that the old GPU works in other PCs, but not mine. Oh well, problem is "solved".
I wasn't sure where to post this question, since I believe it could be a few different issues. Since it is my Graphics card that doesn't work, I guess I'll post it here.
GPU - AMD RX6700 XT
My PC was working without issue for years. I had a loud clicking sound from my PC that I suspected was my liquid cooler. After changing the liquid cooler out for a air cooler, my GPU stopped working on first boot after replacement. The PC would start, but no video. The MOBO VGA light stayed orange. I was able to plug my monitor into my MOBO video output, that worked fine.
I changed my GPU to an old RX 580 I had. The 580 GPU also worked fine. I put my RX6700XT in a different computer, that worked.
I ordered a new 6650XT GPU, but I suspect my issue may be my PSU. But why would my PSU have no issues until after I changed out my liquid cooler?
Any other thoughts on what my issue may be? Thanks.
GPU - AMD RX6700 XT
