Question AMD Ryzen 5 3600 and ASRock X570 Steel Legend WiFi ax ATX AM4 Motherboard
Aug 17, 2019
I am building out a PC to be used with Abobe Creative Suite. No games.
I have purchased
AMD Ryzen 5 3600
Western Digital WD 500GB Black High Performance NVMe SSD PCIe Gen3 x4 M.2 2280 STD- WDS500G2X0C-OOL350
Would like advice on
Sapphire Pulse Radeon GPU RX590 8GB PCIe GPU
or
Sapphire Pulse Radeon GPU RX580 8GB PCIe GPU for $20 less
G.SKILL Ripjaws V Series 32GB (2 x 16GB) 288-Pin DDR4 SDRAM DDR4 3200 (PC4 25600) Desktop Memory Model F4-3200C14D-32GVK
or
G.SKILL Sniper X Series 32GB (2 x 16GB) 288-Pin DDR4 SDRAM DDR4 3200 (PC4 25600) Intel X299 / Z370 / Z270 / Z170 Desktop Memory Model F4-3200C16D-32GSXKB for $50 less
Pros and Cons
Thanks
ConanLock
Commendable
May 22, 2019
1,117
238
1,240
38
The RX 590 is a faster GPU than the 580, and so in programs that use GPU acceleration, the 590 is the better choice. For $20, I think it is worth it.
For the RAM, the F4-3200C14D is the better performing choice. It's CAS Latency is 14, while the cheaper one is 16. For anything that gets loaded into the RAM, which is a lot in Creative Suite, the CPU will be able to access this a lot quicker. Once again, if your budget allows for this, the more expensive choice wins.
Reactions: Vic 40
