[SOLVED] AMD Ryzen 5 5600g and Asrock B550 ITX/ax compatibility issue
Dec 19, 2021
Hi I built a pc using the AMD Ryzen 5 5600g as my APU and the ASRock B550 ITX/ax motherboard, but when I turn on the pc nothing comes up on my monitor. All the fans work, and the ram and motherboard light up. I'm thinking it could be an issue with the BIOS? The mother board is version P1.2 but the processor requires P2.0. Does it mean I have to use a different processor and graphics card to flash the BIOS? or is there another solution available?
PC Build: https://pcpartpicker.com/list/ZZmVt8
Compatibility: https://www.asrock.com/mb/AMD/B550 Phantom Gaming-ITXax/index.asp#BIOS
P.S. There is no flash BIOS button on the motherboard side panel.
then you need to update the bios to the latest (2.20) to get it to work. You will need to bring it to local pc shop where you bought the mobo and ask them for updating the bios to the latest. or at the very least, use ryzen 3 3200g to get it to work.
Latest posts
