• Hey there, Guest! Share your idea for a new trophy in the forums and win bragging rights and a $100 Amazon gift card! Check out the New Community Trophy Contest here!
  • Pardon our dust as we work on some regularly scheduled forum maintenance. You may notice some missing features during this time. Thank you for your patience!
AMD system build check for first time build
ldanielb
11
This would be the first time I've actually built a PC and I don't know much about AMD systems, but I would like to use AMD for the price point. Can you guys look over my build below and see if i have made any glaring errors or give suggestions?
APPROXIMATE PURCHASE DATE: a couple of weeks
BUDGET RANGE: 800
SYSTEM USAGE FROM MOST TO LEAST IMPORTANT: gaming, surfing the internet, watching movies
PARTS NOT REQUIRED: keyboard, mouse, monitor, speakers, OS
PREFERRED WEBSITE(S) FOR PARTS: newegg.com
COUNTRY OF ORIGIN: U.S.
PARTS PREFERENCES: AMD athlon, I would like to stick to the athlon II, and maybe upgrade to the phenom II later
OVERCLOCKING: Maybe
SLI OR CROSSFIRE: No
MONITOR RESOLUTION: 1600x900
ADDITIONAL COMMENTS:none
Case
Antec Three Hundred Illusion Black Steel ATX Mid Tower Computer Case
http://www.newegg.com/Product/Product.aspx?Item=N82E16811129066
MoBo
GIGABYTE GA-770TA-UD3 AM3 AMD 770 SATA 6Gb/s USB 3.0 ATX AMD Motherboard
http://www.newegg.com/Product/Product.aspx?Item=N82E16813128419
Video Card
XFX HD-585X-ZAFC Radeon HD 5850 1GB 256-bit GDDR5 PCI Express 2.1 x16 HDCP Ready CrossFireX Support Video Card w/ Eyefinity
http://www.newegg.com/Product/Product.aspx?Item=N82E16814150477
Power Supply
Antec EarthWatts EA650 650W Continuous Power ATX12V Ver.2.2 / EPS12V version 2.91 SLI Certified CrossFire Ready 80 PLUS Certified
http://www.newegg.com/Product/Product.aspx?Item=N82E16817371015
CPU
AMD Athlon II X4 630 Propus 2.8GHz Socket AM3 95W Quad-Core Processor Model ADX630WFGIBOX
http://www.newegg.com/Product/Product.aspx?Item=N82E16819103704
RAM
CORSAIR XMS3 DHX 4GB (2 x 2GB) 240-Pin DDR3 SDRAM DDR3 1333 (PC3 10666) Dual Channel Kit Desktop Memory Model
http://www.newegg.com/Product/Product.aspx?Item=N82E16820145198
Hard Drive
SAMSUNG Spinpoint F3 HD502HJ 500GB 7200 RPM SATA 3.0Gb/s 3.5" Internal Hard Drive -Bare Drive
http://www.newegg.com/Product/Product.aspx?Item=N82E16822152181
Optical Drive
Sony Optiarc 24X DVD/CD Rewritable Drive Black SATA Model AD-7240S-0B - OEM
http://www.newegg.com/Product/Product.aspx?Item=N82E16827118030
I really would appreciate any advice or suggestions you have. Thanks!
ldanielb
11
I'll definately have to go with the ram you suggested. And thanks for the tip on the Case and PSU combo. I copied all of this from a wishlist that i set up @ newegg and i added all of the parts serperately due to not being able to save combo deals to a wish list.
Onus
I like the mobo batuchka linked, especially considering the OP's stated intention to upgrade his CPU later. This suggests a desire for as much future-resistance as possible, which this board seems to offer.
I really don't see the point in getting a 8xx chipset. All AM3 boards are just as future proof, they just might need a BIOS update for the newer CPUs. Frankly, I think it's less future proof mainly because it's a lower quality ASRock board...
Yep and the peeps at Xtremesystem forums have been going at it with the 890GX version ^^ Review
http://en.ocworkbench.com/tech/exclusive-review-asrock-880g-extreme3-amd-880g-sb850-mainboard-with-ucc-to-uncover-the-hidden-cores/12/
In Conclusion, I feel that the ASRock 880G Extreme3 is a board that you should watch out for in your next upgrade purchase. It is one of the best price/performance board available in the year 2010. We give it our Editor’s Choice award.
Pros
USB 3 support
UCC
Power switches, Clear CMOS switch at the back
Cons
No DisplayPort
Category Score
Performance 10 / 10
Features 10 / 10
Ease Of Installation 9 / 10
Overclocking Features 9 / 10
Documentation 7 / 10
Packaging 8 / 10
Cost / Performance 10 / 10
Overall Rating : 9 / 10
Similar threads
