AMD System monitor
cheek666
20
Hi quick question
In amd system monitor there is an option in the top right to record your readings which get saved in a recordings folder but how do you view these recordings?
"The recordings are stored in the directory you installed the “AMD System Monitor” in, within a folder named “Recordings”. The default path is “C:\Program Files (x86)\AMD\System Monitor\Recordings\w”. The recordings are stored in a CSV file format. You can view these files in Microsoft Office or OpenOffice, as well as with other programs if you want."
Source: http://www.jagtutorials.com/VideoPages/V_AMDSystemMonitor.html
