Question AMD Wraith Spire RGB Problem
karambae
4
So I just got a Ryzen 7 2700 w/ the wraith spire cooler. My motherboard is a TUF B350m-plus Gaming which is "Aura Compatible" according to the website. Whenever I try to install and start Aura Sync I am greeted with the error message "AuraService is currently unavailable. Please close Aura and check if AuraService is installed and started properly." and there is nothing else I can change the lighting settings with (to my knowledge). I have tried every fix I could find and none so far have worked so if you have anything to suggest PLEASE let me know. Thanks!
