M Milan Nikolov Reputable Nov 8, 2014 13 0 4,510 Jul 11, 2015 #1 I have problem with potentiometer on amplifier. I don't know amp model, because it is homemade amp. How do I know that the strength of the potentiometer is needed for that amp? Thanks in advance.
Solution kanewolf Jul 11, 2015 It may have a resistance printed on it. If it is not open, you could disconnect it from the rest of the circuit and check it with an ohm meter.
kanewolf Titan Moderator May 29, 2013 37,322 3,277 156,790 Jul 11, 2015 Solution #2 It may have a resistance printed on it. If it is not open, you could disconnect it from the rest of the circuit and check it with an ohm meter. Upvote 0 Downvote Solution
makkem Distinguished Jan 22, 2012 1,962 5 20,965 Jul 12, 2015 #4 Hi Just to add to that,when you determine the resistance and come to buy the pot you will need a log one not a lin as it is a volume control. Upvote 0 Downvote
kanewolf Titan Moderator May 29, 2013 37,322 3,277 156,790 Jul 12, 2015 #5 makkem : Hi Just to add to that,when you determine the resistance and come to buy the pot you will need a log one not a lin as it is a volume control. Good point!! Upvote 0 Downvote
