Amplifier to speaker problem
So I had this Sony speakers set which had an amp thingy. The speakers are good but the amp thingy in bw is spoilt. I intend to buy an amplifier that'll provide me enough bass and volume and everything...
My speakers:
Sony SS-RV900
6ohm, 140+140w, 3 way.
My old amp thingy
Sony MHC rv5
Please suggest some amplifier or something that'll help me buy one in my country ( India)
Thanks!
The original amp thingy is rated at 120 watts per channel at 6 ohm but at 10% distortion which is very very high.
I would say that you can use any amp with about 50-75 watts into 6 ohms at a more normal .01% distortion. I'm not sure what brands are available to you and what price range you are looking to spend. Some options would be
https://www.mysmartprice.com/electronics/cambridge-audio-topaz-am5-integrated-amplifier-msf427906
https://www.mysmartprice.com/electronics/yamaha-r-s500-sound-stereo-receiver-msf226802
Don't buy a surround sound receiver unless you plan on adding speaker or need some of the connections. A stereo receiver will be more economical and may sound better too.
