An error was detected on device \Device\Harddisk2\DR2 Paging
rzr09
42
Right i keep getting this bluescreen error, but it cannot be the HD ive only had it for 4 months, or could it be? :pt1cable:
drevin
91
It's perfectly possible for a new drive to fail. As it says "Harddisk2", it means the 3rd HDD (starting from 0). It could also mean 3rd partition, not sure about that. Do you have more than one hard disk?
rzr09
42
I have to 3 HD all together 2internal 1 external how could i find the numbers so i would know wich is failing :)
EDIT: could it be my external one then ?
drevin
91
I'm not completely sure, but it would make sense that Windows would treat the external drive as the last one. Probably SATA/IDE drives first, then external ones.
rzr09
42
Ok D.C my external one, going to See how things go cheers bud!
rzr09
42
Yup it was my External that was causing the prob :) checked with disk management
