I just built a computer for a friend of mine, but there is a problem. The problem is that the computer won't start unless the GPU is receiving power and it won't receive power correctly. For the GPU to be receiving power, the 6-pin PCI-E power connector has to be positioned in a way that someone would have to be putting pressure on it, and if you were to let go the whole computer would shut itself off. It is a very strange problem. How do I fix it?
Specs:
AMD Phenom II X4 965 Quad Core @3.2 GHz CPU (Hyper 212 Evo)
ASRock 970 Extreme3 Motherboard
8GB (2x4GB) Kingston HyperX Black ram.
ASUS Nvidia GTX 650 GPU
NZXT M59 Case
Antec BP550 550w PSU
2x Cooler Master Top Exhaust 120mm Case Fans (If that matters)
I believe the problem is the motherboard, is that correct?
Specs:
NZXT M59 Case
