So I have a main gaming PC and then I have a quiet place PC upstairs. It's twelve years old rocking a Pentium 4 HT 3 GHz, 1024 MB DDR-400, and what looks like an ATI Radeon 9200 (AGP card, of course) and had windows XP 32 bit. It was my "Homework and whatever game can run and sometimes Skype machine"
Recently, the 160GB Maxtor HDD started flashing errors, system flashed with "Reboot or select proper boot device and press a key" kind of screen.
I paid a visit to my grandfather's majestic PC stash with nothing made after 2004, found an identical PC with a 160GB Maxtor HDD and an 80GB Seagate. I also noted on the way back you tend to feel all the damned frost heaves and bumps in the road when you're carrying sensitive cargo.
When a drive is installed and system is powered on, at the BIOS flash, there is a beep, and it says "DRIVE ERROR (A
Going into BIOS setup shows that when a drive is installed, that drive is reported as installed.
When attempting to load any operating system, the PC goes to "Reboot or select proper boot device" screen.
Is it safe to assume my drive is dead? What possible fixes / tests could I conduct?
Onto part two (assuming drives are both dead)
Here's what my motherboard looks like. I believe it's called something like ASUS P4SD-LA
https://www.pcbitz.com/content/images/products/17114/thumbnail/hp-asus-p4sd-la-rev-106-socket-478-motherboard-no-bp-2.jpg
http://ruthusher.com/wordpress/wp-content/themes/Glider/temp/motherboard-p4sd-la-i5.JPG
At the bottom right near the blue IDE port, there are two what look to be SATA ports. I DO have an intact 250 GB 7200 RPM HDD that is as nearly as old as SATA is, is it possible to use?
Power connectors aren't a problem. I got plenty of PSU's and adapters.
![Smile :) :)](/data/assets/smilies/smile.gif)
