And LED configuration you'd recommended over the NZXT Hue+?
Arishok N7
389
Been looking around for a wow factor for a while now. The inside of my PC pretty much has no LED's or anything. I stumbled upon the Hue+. What do you guys think? Are there better options?
You dont "Need" a 2.5" bay free, you can hide it anywhere in your case really, I have mine tucked in next to my power supply becuase its kinda the only place that'll fit. If you do however use a free slot, definitely screw each corner into...
Hey dude,
yeah the NZXT Hue+ is an amazing LED lighting solution, i currently have it installed in my pc and the freedom in customisation is limitless!
I recommend watching this video because it gives you a really thorough review and guide ( it does go for 30 minutes though)
In my opinion this is the best but, you will need to have a spare 2.5" slot free as the unit requires one, NOTE: the unit is roughly taller than an SSD by X2 so dont install at the back of the case.
Best regards Joy0003
You dont "Need" a 2.5" bay free, you can hide it anywhere in your case really, I have mine tucked in next to my power supply becuase its kinda the only place that'll fit. If you do however use a free slot, definitely screw each corner into place, NZXT advises you only use the front mounts but use all to keep it firm.
