A alanconnaughton21 Nov 23, 2018 3 0 10 Nov 23, 2018 #1 Any time you stream something the box's goes back to home screen after about an hour it's like it switche's off and on again it's only a new box
Solution A A alanconnaughton21 Nov 23, 2018 Hi guys got it sorted power cord was faulty I had a similar power cord tried it and hasn't happened since so happy days
A Alabalcho Titan Jan 13, 2011 14,019 435 76,290 Nov 23, 2018 #2 It might overheats, or be defective. Reset it to factory defaults, and try again. If it is new one - talk with the seller / manufacturer for support. Upvote 0 Downvote
A alanconnaughton21 Nov 23, 2018 3 0 10 Nov 23, 2018 #3 Alabalcho : It might overheats, or be defective. Reset it to factory defaults, and try again. If it is new one - talk with the seller / manufacturer for support. Upvote 0 Downvote
A alanconnaughton21 Nov 23, 2018 3 0 10 Nov 23, 2018 Solution #4 Hi guys got it sorted power cord was faulty I had a similar power cord tried it and hasn't happened since so happy days Upvote 0 Downvote Solution
