Android tablet wifi authentication problem
gefraenk
5
Hello, every wireless device works except my new tablet from Acer running Android 4.1.1. My SID contains number of spaces. I am using WPA2 with password containing spaces, even my old Blackberry works... I get Authenticating ... and never comes back...
inzone
Champion
What are you trying to connect to ? A wireless router ? Have you entered the network password into the Acer tablet ? If you go into the router is the Mac address for the Acer tablet in there with all the other evices ?
gefraenk
5
Yes, I try to connect to the network router.
I solved this issue by broadcasting the SSID, which I don't like to do, because of a number of intrusions attempts, in the past....
ex_bubblehead
Champion
Hiding the SSID, in addition to being a violation of the 802.11 RFC is not an effective security measure. The SSID is actually broadcast in 4 places during a connection attempt (none of which can be stopped) and is easily discovered by sniffing traffic. You'll also encounter connection problems with any equipment that strictly follows the RFC. Using an advanced encryption (WPA2-Personal or Enterprise) is far more effective at stopping any unauthorized entries.
http://www.howtogeek.com/howto/28653/debunking-myths-is-hiding-your-wireless-ssid-really-more-secure/
bluk
Hello all, I have the same authentication problem, worse, I m not sure what SID /SSID stands for, nor how the earlier other writer here solved his problem, legally or less than legally.
I have entered my network password on the MID ANDROID tablet, but the message I receive is Authenticating...,then Sved, secured with WPA, befor it switches back to Authenticating... in an endless loop until it goes to sleep. No othe device in the house / yard has had this problem and I am abslutely CERTAIN that I entered the right password.
WHAT TO DO NEXT?
gefraenk
5
SSID stands for service set id which is your unique network name.
In your router menu settings, can be found under wireless settings.
By default, if you do not set your own name, the router gives it a long cryptic generated name.
If you don't know how to find your SSID name, download e.g. Wifi Location Tracking software from sourceforge.net and install it on your wifi enabled laptop.
G
Guest
Guest
I am having the same issue
kjdillon
I am having the same problem. My PC works on the WiFi, but my two Android devices don't. They get the same Authenticating run-around. Yet they work on WiFi in other locations. Does anyone have a solution? Thanks.
fatmangre6br
How do you hide the SSID?
Saga Lout
Olde English
I cant put my hands on one of those at the moment but I could later if necessary. Anyway, what you're looking for in Wireless settings is where it names itself - BTHomeHub 11-VV, BTHub3-1ZXZ or whatever. You can overwrite that and call it something else if you wish but the setting to display it to the outside world is there somewhere.
Hoots Fandango
I had this problem then I examined the code on the back of the router, but this time with a magnifying glass. I had keyed in the number 5 when it should have been a capital S. No authentication problem now.
