animation and rendering pc for 70k
hi thanks for the repl.....70k.....indian repees ....70.000.....
monitor
processor
graphic card
motherboard
cabinet
power supply
and i have key board mouse and speakr....
hi thanks for the repl.....now my budget is increased ....my budget is 90k.... means 90.000m eans 15000 dollar
and my software is --autodesk 3ds max 2014 and autodesk maya 2014, adobe photoshop
this is the indian web side for computer purchase chk this .....http://www.flipkart.com
no american parts for me not possible to get them....
This build was made with the mind that you don't need anything else with your budget besides these components
CPU: i7-4770 Rs. 21175 http://www.flipkart.com/intel-core-i7-4770-processor/p/itmdhx7zekttk5he?pid=PSRDHTWPVEZSPQKX&icmpid=reco_pp_same_processor_3&ppid=PSRDHSPKXF95EW5G
CPU cooler: Default Intel Cooler
Motherboard: Gigabyte H87M-D3H Rs. 7420 http://www.flipkart.com/gigabyte-h87m-d3h-motherboard/p/itmdmzw9zuhgz8kt?pid=MBDDMZW9ZUHGZ8KT&srno=b_1&ref=931a80c4-2ed3-4da7-b14f-b40c8c66f512
RAM: G.Skill RipjawsX DDR3 16 GB (2 x 8 GB) Rs. 13300 http://www.flipkart.com/g-skill-ripjawsx-ddr3-16-gb-2-x-8-gb-pc-ram-f3-12800cl10d-16gbxl/p/itmd8bc6bjdvpucr?pid=RAMD8BC6AV3GXS9G&srno=b_4&ref=d3ed6dfc-5d6a-49b0-956c-6b2ae6c1cb04
SSD: ADATA Premier Pro SP900/128GB Rs. 6400 http://www.flipkart.com/adata-premier-pro-128-gb-ssd-internal-hard-drive-premier-sp900-128gb/p/itmdrbcybpjhdtjh?pid=IHDDRBCYBPJHDTJH&srno=b_1&ref=f523dd86-0684-4736-91a5-245b037cc3a0
HDD: Seagate Barracuda 2 TB Rs. 6149 http://www.flipkart.com/seagate-barracuda-2-tb-desktop-internal-hard-drive-st2000dm001/p/itmdd2hhuz4ssukn?pid=IHDDD2HHUZ4SSUKN&srno=b_1&ref=0d4e0f1a-422b-45a4-8c1e-a85f8b86edae
GPU: MSI NVIDIA N770 TF 2GD5/OC Rs. 35900 http://www.flipkart.com/msi-nvidia-n770-tf-2gd5-oc-2-gb-gddr5-graphics-card/p/itmdmhfzhtuk8cff?pid=GRCDMHFZHTUK8CFF&srno=b_1&ref=68870b30-a0a6-4d0d-b93f-0f85bf052b26
PSU: Seasonic S12II 620 Rs. 6150 http://www.flipkart.com/seasonic-s12ii-620-watts-psu/p/itmd5xz46hjzzrax?pid=PSUD5XZ4GCGRASAY&srno=b_1&ref=a92eda77-9460-49a7-a6b5-2e464c4fa79d
Total: 90344
plz chk my list ....and tell me ur opnion abt my list
Intel 4770K i7 -- 23550
Asus Z87 Pro Motherboard 17278
asus nvidia 770 32000
aoc monitor 11000
Corsair Vengeance DDR3 8 GB 6100
2 tb hard drive 6200
coller master 750w 8200
coller master cabinet 3500
coller 8000
total 115000
Well it's over the budget, and are you looking to overclock your build? If you aren't going to overclock, stick with i7-4770 and H87 chipset.
I would go with 16 GB of RAM since video editing and creation does use up a good amount of RAM and 8 GB might not be enough.
can u tell me what is the diffrent between i7-4770 and i7-4770k....what is a overclock????
and ill upgrade ram 8 to 16gb
In Intel's dictionary, a K version of a CPU means that it is unlocked. Unlocked means that with a compatible motherboard, you will be able to fully control and overclock your CPU as you wish.
Overclocking means to push your CPU out of the recommended operating frequency, it is a way to get more performance for the price that you've paid. However, overclocking does take patience and skill to accomplish a reasonable stable overclock. If you just want to have the PC up and running like it suppose to without messing with anything else, then I recommend you to not overclock.
In addition, as I've mentioned above that not overclocking can also save you some money on the CPU itself and the motherboard.
