Annihilator 2 Problem
G
Guest
Guest
I just bought a creative annihilator and it give me so many problem such as freezing up my computer. I am using Asus K7V motherboard 128Mb 133Mhz Ram Athlon 800 Mhz. I already try to reinstall Win98SE and update the driver but it still give me the problem. HELP!~~~
kangaroo
27
u can try to flash ur mobo BIOS, install the via 4 in 1 driver, run ur AGP at 2x with fastwrites off ..... also try to check out www.geforcefaq.com , it has a lot of info.
G
Guest
Guest
Win 2K impossible to crash? Bah! I do it all the time!
LOL!
No really, your right. Win2K is WAY more stable.
G
Guest
Guest
I had a similar problem when trying to set up a 600 Mhz Duron w/ FIC AZ11 mobo. Could not get it to be stable. I don't blame AMD. I think that it is pot luck getting Nvidia boards to work with VIA chipsets. Maybe things have changed since then, but I would rather have stability than speed. I dropped back to the Intel platform.
