Hi all, recently bought a new system.
NZXT Source 210 Elite Gaming Case + 600W Corsair PSU [£29.21]
Gigabyte GA-Z77-D3H, Intel Z77 Chipset [£66.77]
Intel Core i5 3570K, Ivy Bridge, 3.4GHz, Quad Core, 3.4GHz, (4.4ghz) 6MB Cache
8GB (2x4GB) Corsair DDR3 Vengeance - 1600MHz
2GB XFX Radeon HD 7870 DD
I play on 1280x1024 atm on a old monitor and I am using one of them vga to dvi converters for the card to work.
I notice when I am playing graphic intensed games like Borderlands 2, gw2 crysis.
The card makes a kinda of a high pitched noise when it is under load. it is very annoying.
When I play games like fallout new vegas which dont use that much gpu power it doesnt make any noise?
I checked CCC and checked the readings, max temp is around 50-60, so the temp is ok,
should I alter the manual fan control setting, thought it was my fans just spinning like crazy.
any input would help
thanks guys
thanks guys
