Annoying Stutter Issue
Aspyyy
Commendable
Dec 12, 2016
I recently moved my computer and I'm now using wireless internet, just a few days ago I noticed that whenever I listened to music, watched a video, or played a game my audio and screen froze for about half a second, then returned to normal, this happens every few seconds and my computer is basically unusable.
Specs:
AMD FX-6300 3.5GHz 6-Core Processor
ASRock 970 PRO3 R2.0 ATX AM3+ Motherboard
A-Data XPG V1.0 8GB (1 x 8GB) DDR3-1600 Memory
Western Digital Caviar Blue 1TB 3.5" 7200RPM Internal Hard Drive
EVGA GeForce GTX 960 4GB SSC GAMING w/ACX 2.0+
Corsair Builder 430W 80+ Bronze Certified ATX Power Supply
Windows 10
Temps: http://imgur.com/a/CxBu1
Edit: I was looking over other posts, and I think I found the source of the problem, I have a ASUS PCE-N15 11n Wireless LAN PCI-E Network Card and another person is having the same problem.
Try simply run command prompt as administrator and then paste in these commands one at a time:
bcdedit /set disabledynamictick yes
bcdedit /set useplatformclock true
Try disabled the ASUS PCE - N15 11n Wirelss LAN PCI-E Card driver in Device Manager. If this fixes the issue then you may want to get one of those usb wifi sticks.
