Another First Time Build. Help and advice.
Shadewolf403
Current computer build: http://pcpartpicker.com/p/nBBE
Approximate Purchase Date: Beginning of December
Budget Range: $900-$1100(best price for performance)
System Usage from Most to Least Important: Gaming, movies and Internet browsing
Are you buying a monitor: Yes
Do you need to buy OS: Yes
Preferred Website(s) for Parts: I was usingpcpartpicker.com and I also live close to a Memory Express.
Parts Preferences: best price for performance.
Overclocking: Yes
SLI or Crossfire: Maybe in the future
Your Monitor resolution: 1080p
Additional Comments: First time builder just looking for advice and input.
boulbox
1,880
I do not use Blu ray/optical drives often, only time i use it is to install things and if i am watching a movie i either download load it in high quality or just stream it inside of rent/buying blu ray disks
CPU: Intel Core i5-3570K 3.4GHz Quad-Core Processor ($169.99 @ Microcenter)
CPU Cooler: Cooler Master Hyper 212 EVO 82.9 CFM Sleeve Bearing CPU Cooler ($26.29 @ NCIX US)
Motherboard: ASRock Z77 Extreme4 ATX LGA1155 Motherboard ($127.98 @ Newegg)
Memory: Samsung 8GB (2 x 4GB) DDR3-1600 Memory ($35.99 @ Amazon)
Storage: Seagate Barracuda 1TB 3.5" 7200RPM Internal Hard Drive ($49.99 @ Newegg)
Storage: A-Data Premier Pro SP900 128GB 2.5" Solid State Disk ($99.99 @ Newegg)
Video Card: Asus Radeon HD 7870 GHz Edition 2GB Video Card ($229.98 @ NCIX US)
Case: Corsair 300R ATX Mid Tower Case ($74.99 @ Amazon)
Power Supply: XFX ProSeries 750W 80 PLUS Silver Certified ATX12V / EPS12V Power Supply ($99.99 @ Amazon)
Optical Drive: Samsung SH-222BB/BEBE DVD/CD Writer ($17.99 @ CompUSA)
Operating System: Microsoft Windows 7 Home Premium SP1 (64-bit) ($99.99 @ Newegg)
Total: $1018.17
(Generated by PCPartPicker 2012-11-15 18:40 EST-0500)
the ram seems a bit cheap but i can tell you it is not. the timing may be a bit high but you can OC this kit to a good amount. getting a 9-9-9-24 @ 1600 under 1.5V is very easy to achieve
malbluff
Only slight problem, I'm not sure about del to Canada, so have used Canadian sites.
CPU: Intel Core i5-3570K 3.4GHz Quad-Core Processor ($219.99 @ NCIX)
CPU Cooler: Cooler Master Hyper 212 EVO 82.9 CFM Sleeve Bearing CPU Cooler ($28.91 @ DirectCanada)
Motherboard: Gigabyte GA-Z77X-UD3H ATX LGA1155 Motherboard ($139.99 @ Memory Express)
Memory: Crucial Ballistix sport 8GB (2 x 4GB) DDR3-1600 Memory ($39.50 @ DirectCanada)
Storage: Samsung Spinpoint F3 1TB 3.5" 7200RPM Internal Hard Drive ($79.99 @ Newegg Canada)
Storage: Samsung 830 Series 128GB 2.5" Solid State Disk ($123.33 @ DirectCanada)
Video Card: MSI Radeon HD 7850 2GB Video Card ($179.99 @ NCIX)
Case: Zalman Z9 ATX Mid Tower Case ($38.98 @ DirectCanada)
Power Supply: XFX ProSeries 750W 80 PLUS Silver Certified ATX12V / EPS12V Power Supply ($94.99 @ NCIX)
Optical Drive: Asus BC-12B1ST/BLK/B/AS Blu-Ray Reader, DVD/CD Writer ($49.99 @ Canada Computers)
Operating System: Microsoft Windows 7 Home Premium SP1 (64-bit) ($96.99 @ Computer Valley)
Total: $1092.65
(Generated by PCPartPicker 2012-11-15 18:59 EST-0500)
You could use the cheaper ASRock mobo, but I'm not sure it's ideal for a first build (does have its quirks). Have used cheaper, but OK case to allow for Ivybridge processor, and better mobo.
An alternative approach might be to save money, with a locked processor, which would free money for better case and GPU.
You would give up some ability for crossfire, but better GPU, you'd have much higher immediate performance.
CPU: Intel Core i5-3470 3.2GHz Quad-Core Processor ($184.99 @ Newegg Canada)
Motherboard: Asus P8H77-V ATX LGA1155 Motherboard ($94.99 @ Canada Computers)
Video Card: MSI Radeon HD 7950 3GB Video Card ($269.99 @ NCIX)
Case: Antec Three Hundred Two ATX Mid Tower Case ($54.79 @ DirectCanada)
Power Supply: XFX 550W 80 PLUS Bronze Certified ATX12V / EPS12V Power Supply ($59.99 @ NCIX)
Total: $1054.55
(Generated by PCPartPicker 2012-11-15 19:10 EST-0500)
boulbox
1,880
revamped it to canada prices
Motherboard: Asus P8Z77-V LK ATX LGA1155 Motherboard ($124.99 @ NCIX)
Memory: Mushkin Silverline 8GB (2 x 4GB) DDR3-1600 Memory ($32.99 @ Newegg Canada)
Storage: Seagate Barracuda 1TB 3.5" 7200RPM Internal Hard Drive ($49.99 @ Newegg Canada)
Storage: A-Data Premier Pro SP900 128GB 2.5" Solid State Disk ($95.99 @ Computer Valley)
Video Card: Asus Radeon HD 7870 GHz Edition 2GB Video Card ($229.99 @ Canada Computers)
Case: Antec Eleven Hundred ATX Full Tower Case ($79.99 @ Newegg Canada)
Optical Drive: Samsung SH-222BB/BEBE DVD/CD Writer ($17.93 @ DirectCanada)
Total: $975.76
(Generated by PCPartPicker 2012-11-15 19:32 EST-0500)
memeryexpress should have that price match deal if i remember correctly.
