First time here! Just spent the whole day installing a Gigabyte GA-P35-DQ6. Like many others (it seems) I cannot get the thing to POST. The CPU fan goes on for a second then cuts off. Tried another power supply with no luck. This is a replacement for a ASUS P5W-DH-Delux which worked for months on this power supply.
The problem exists even if I have the MB out of the case with power supply, keyboard, mouse and Videocard connections.
Yes I have both power supply connections to the board (24 pin & 4pin/6pin).
I see some mention of people with memory voltage problems for Corsair with old BIOS's. Now I just got this board today. Do people think the voltage issue is corrected in the BIOS by now. I have a bit of a chicken & egg problem in that I cannot tell what I have got until it boots!
I also see people returning MB's because of the above problem. Did their "new" board work.
Any suggestions as to a 1 or 2 Gb memory that definatly will work. What criteria should I use.
