Building a Antec 1200 gaming computer and I know it comes with 5 120mm and 1 200mm fan. Looking to get 2 more fans, 1 for the side panel and another to go onto the gpu. I am looking for the same blue the stock case fans give off.
There is a antec 120mm tri-color fan http://www.newegg.com/Product/Product.aspx?Item=N82E16835209011
It sells on newegg for $14.99, yet I am seeing other 120mm fans with blue led for a little cheaper. So I'm here to ask if there is another 120mm case fan that gives off the same blue led as the stock antec 1200 because in some pictures they look light blue. Or should I just get the one I linked above?
