I only recently started using the front headphone jack on my Antec 900 and started noticing a light but noticeable hum coming from my headphones. AFter some digging around, it looks like a common problem with Antec cases are ground loops. I dont fully understand how it works but in short, this problem causes the humming from the speakers. A quick google search netted me these two links:
http://www.incrysis.com/forums/viewtopic.php?id=29778
http://www.eggxpert.com/forums/thread/312283.aspx
Both of those links detail similar issues and a variety of fixes but none directly address the Antec 900 so I tried to fix it myself assuming the cases were built similarly.
To keep it short, I managed to get as far as the wiring for the front panel USB ports/microphone/headphone jacks but everything is enclosed in this small black plastic casing that looks like it can only be removed with a sharp object and brute force which would leave the thing demolished and unable to be repaired..leaving me with a mess of those wires.
I tried purchasing one of those Ground Loop Isolators and that dims the noise but doesnt eliminate it.
Has anyone ever successfully eliminated this Antec 900 ground loop problem? Any ideas on how I can? Any suggestions on an alternative method I cant take to get rid of it?
I have my 2.1 speakers plugged into the rear headphone jack and would like to use the front headphone jack whenever I game online and use ventrilo or teamspeak.
