Antec 900 Side Panel Replacement
zodiac949
121
Hey guys, I'm having some difficulties in finding a left side panel for the antec 900. At this point I'm just looking for a panel that fits (preferably with a side window). The trouble is that while Antec has a posted replacement for sale...
http://store.antec.com/Product/accessory-spare_parts/nine-hundred-left-side-panel/0-761345-30045-2.aspx
The part has been out of stock for what seems to be several months, and I'm not sure where I can locate something that would fit.
Thanks in advance,
zodiac.
Ask one of there support reps, they may be able to procure one, i doubt side panels are one of those things they keep a large stock of, they can't move too many of them. http://www.antec.com/Believe_it/index.php?page=support_online
There don't seem to be any on amazon so if antec doesn't have them your best bet would probably be to find a used 900 and take its side panel. What is wrong with yours? It may be repairable and that could be the easier option.
I was modding the side panel without the proper tools several years ago. I damaged it pretty badly and I think it would be the best option to replace it. Contacting a rep might be a good idea, just considering my options at this point.
