Question Antec DP501 glass panel replacement ?
acaciusx
59
Side panel broke down,
Not sold anymore in ny country by the importer or any 1 else.
I cant seen to find the exact dimensions of it anywhere,
Always leads me to the case itself search or the : side panel glass catageroy
Could any 1 might help me either by having 1 and measure it in cm/inch and ill convertor maybe knows of another glass panel that could fit instead?
Just buy a sheet of plexiglass and make yourself a new case side glass door.
The difficult part is to cut the sheet with the correct sizes and drill the four screw holes, if it's beyond your DIY ability, you can hire someone to do that job for you.
