Antec Kuhler for my siverstone sg04-f model is their any problem to install
ajmj 11
hi im asking about the cpu cooler antec kuhler h20 620 to my silverstone sg04-f casing model is it ok to install
As long as your case can handle a 120 mm fan you can install it. If you get a second set of long screws you can even add a fan and put the H20 620 into a push/pull configuration. I did and it is almost as good as the Antec 920 (which I have in my gaming case).
