Antec led fans on/off switch for led
Kalekills
I just got in my Antec 900 case. I have also purchased a Red Tricool antec fan and two Antec TrueQuiet 120 to replace the factory Blue fans.
I want the fans to run normally, but want to splice in an external switch. So I can turn the LED's off at night when I don't want them on anymore.
I looked for a tutorial, but only found info on Cooler master fans. I have already purchased these fans before I realized they had fans on the market with this option already installed.
I can solder, and have all the necessary crimps and shrink sleeves to alter the wiring.
I peeled the sticker back a little bit, on the center of the fan. My question is all the LEDs are wired into the board. If I want to run them on a switch will I have disconnect all of them and run them on an independent circuit, pig tailing off the power and ground? - I am new here and have not figured out how to post an image but here is a link to the fan.
http://www.scan.co.uk/products/120mm-antec-truequiet-120-white-case-fan-white-led-with-manual-2-speed-switch?ProductId=68960
https://www.youtube.com/watch?v=db7FtMytj7s
This video has a notation that this only works on cooler master. If it applies ill follow this tek
in the image you can see the individual power wires running to the board
