Hi all,
First of all sorry for my english.
I've just made a system based on antec p280 case. The system has:
Intel Core i7 4770 Haswell 3.4ghz (http://ark.intel.com/products/75122/Intel-Core-i7-4770-Processor-8M-Cache-up-to-3_90-GHz)
Gigabyte NVIDIA GeForce GTX 750 Ti OC WINDFORCE 2X, 2048MB (http://www.gigabyte.com/products/product-page.aspx?pid=4948#sp)
MB - Gigabyte B85M-HD3 (http://www.gigabyte.com/products/product-page.aspx?pid=4568#ov)
Antec P280 black towercase
HDD Seagate Barracuda 1TB
Samsung evo 840 SSD, 120GB
PSU: Super Flower Golden Green SF-500P14XE(HX) 500W
The problem is that the 2 top fans are not as quiet as i would like. They make a noise of zzzz...zzz (don't know how to describe it, looks like a HDD noise but i stopped the fans and the noise dissapered) when i keep them on low speed and when i change on high speed they are even louder, but no zzzz noise.
Now i have a few questions and i would like a little help:
1. Is it safe for my system to stop the 2 top fans? The GPU and CPU temperatures measured while playing Diablo 3 ROS are 58-60 celsius degrees for the GPU and 52-55 for the CPU.
2. If i stop the 2 top fans will the life of my components will be affected? Meaning they will probably last longer with a better cooling.
3. Should i replace the 2 top fans? If so what should i use? Also i would like to use the fan hub from the back of case and the new fans be able to operate at low and high speed just like these Antec twocool from the case. I was thinking at SCYTHE SLIP STREAM SY1225SL12L but don't know if i should take one with PWM fan or not. The price range should be something between 10-13$.
4. Should i also take 2 intake fans for the front of the case or it won't be a need?
All the fans are 120x120x25 and i would like to be as quiet as possible.
Thanks.
Thanks.
