Hi
I have a choice to buy either of these PSU's, Im from Mexico so those are pretty much all the options in my price range with the thermal take being around 10 dollars more expensive.
My PC currently has
Intel I3 3220
ASUS P8Z77-V LX
Corsair Vengeance LP 4Gb in one module
Seagate 1.5TB ST1500DL003 Sata III
and a DVD RW for double layer discs
also have a Ati HD 7850 that i havent used because my current PSU doesnt have a 6 pin connector
I'm currently overclocking the Bus Speed slightly to 103mhz to get 16480mhz from the DDR3's and 3.4 GHz from the processor
and will be overclock the graphics card to get around 1050 mhz in the core and shader clocks from their default 860 and the memory clock to 5800mhz
In the future i think of buying a Xfi xtreme gamer, xtreme audio or xtreme audio pro (without the console) and another Corsair 4gb module.
I was impressed by this review for the antec vp450 http://www.hardwaresecrets.com/printpage/Antec-VP450-Power-Supply-Review/1487
the thermal take is the tr2 600NL2NC cable management without 80 bronze and i havent seen any worthwhile reviews but an user in this forum said that this particular model is 430 minimum and 600 maximum
So wich would be more siutable for my needs?
Thanks
My PC currently has
Intel I3 3220
ASUS P8Z77-V LX
Thanks
