Antec VP500PC vs VP500P power supply
magiccandy061
Both are similar in price and specs, but what is the real difference between the two?
Looking to use it for a motherboard with an 8-pin cpu power and only 1 graphics card.
Real question is, what difference does the "C" make?
PC is made by CWT and the P is made by FSP both are about the same quality.
A bit older platform and not the best quality but should work depending on the parts your going to use. Their not to bad for a budget build but if your using high end parts then spend more their for better quality.
