ANTEC VP550P PSU problem...
harish0692
59
my rig
CPU:- AMD FX - 8350 VISHERA 32nm tech
MOTHERBOARD:- GIGABYTE TECHNOLOGY GA-78LMT-USB3 (SOCKET M2)
GRAPHICS :- GIGABYTE NVIDIA GTX 750 TI
STORAGE :- SEAGATE ST500DM002-1BD142 ATA DEVICE
RAM:- Corsair CMZ4GX3M1A1600C9 Vengeance 4GB Single Module DDR3
got my new psu, system running smoothly bt aftr few hrs i had been observed tat some yellow type in psu ... is there any problem shld i return it and i am uploading the pics which i have taken of psu.. plz help me out ???
http://imageshack.com/a/img910/6122/04yeB4.png
http://imageshack.com/a/img633/5121/y5ZYIg.png
http://imageshack.com/a/img537/1936/qfLck7.png
http://imageshack.com/a/img540/605/4pmjc9.png
That's adhesive used in the manufacturing process to hold components in place (i.e. to prevent them from being pushed out of their mounting holes or to prevent the component from leaning over and possibly causing a short circuit) during the soldering process. In some cases it is used to prevent/dampen coil core vibration.
I would not be concerned. Your pictures seem to show the "glue" they use to secure and insulate certain parts. I would bet that it was there from the start and you just did not notice it. I do not suggest opening the psu to check it out as it voids the warranty. Looks like all is as it should be.
