[SOLVED] Antenna position
wizacs
33
So, I bought a wifi repeater to put it in my garage, that's under my router, so how should I position the repeater's antennas to get the best performance? I thought about putting them horizontally because the router is literally above me.
This won't be too hard to figure out, set things up, and check your connection speed and signal strength. Move the antenna, check it again. 3 or 4 tries should get you the answer.
