[SOLVED] Any alternatives to a Raspberry Pi 4 with built in storage (or storage slot)?
techflame700
Commendable
Nov 30, 2018
116
Title is pretty self explanatory, it’s going into a hard to access location once it’s done and I don’t wanna deal with the headaches of an SD card. I do, however, need it to be as powerful as a Pi 4 or faster. Thanks!
A RPi 4 in an NAS-type enclosure, complete with mounts for HDD or SSD of your choice?
A M.2 SSD in an external enclosure if said hard to access location is also too small for anything larger.
Make sure to set up the watchdog timers too.
if you want a sbc computer with built in storage the only one you're gonna have much luck with is the rock pi x so that's what I'd suggest. It comes with a range of size options and pre-installed with Twister OS so not a bad choice.
