Any case to fit MSI x299 Tomahawk LGA 2066 and CM Masterliquid Pro 240
luisperera89
49
Hi guys,
I bought a few days ago an entire computer build and today I started to put the pieces together. First I placed the motherboard MSI X299 Tomahawk LGA 2066 in the case Rosewill Nighthawk 117 Full Tower Case and afterwards I proceeded to install the Cooler Master MasterLiquid Pro 240; but there was a small problem. The CPU power connector of the motherboard was blocked by the fans of the radiator of the cooler. The case holes where the screws of the motherboard goes were, in my opinion, to high. Can you please advise a good case for this set up? I know in the worst case scenario I have to change the cooler, but out of the three parts, the case is the least I like. Thanks in advance.
had similar isue with a b350 board have to get a 120 mm fan to replace the 140 mm on on top see if you could put them on top as describe in the case booklet also those fam are regular that are from 38 mm or 25 mm see these they are slim one you might need to use similar ones .http://www.coolermaster.com/cooling/case-fan/xtraflo-120-slim/
Yes I did, I removed the fan that came with the case. Below is a picture showing what is going on
