Any Compatibility Problems With My Build?
jamie2001
27
Hello. Sorry for posting so much but these are things I need to know. Will I have any compatibility issues with my build. Most importantly will the graphics card fit into the motherboard and so on.
(SORRY FOR POSTING SO MUCH THIS IS MY LAST POST)
My Specs:
B85-HD3 GIGABYTE MOTHERBOARD
GTX 1050TI GIGABYTE 4GB
BRONZE 500W POWER SUPPLY
8GB RAM
I3 4150 3.5GHZ DUEL CORE WITH HYPER THREADING
Not enough information to answer your question.
8GB ram can't check that without knowing the ram.
Bronze 500 Watt power supply could be garbage could be decent.
Video card it just must fit in the case the motherboard don't matter.
Your using some old hardware for some reason.
