Question Any difference between those Radeon VII Cards?
IamMike
68
IamMike
68
Well ya i need it for memory hungry applications.
I'm just wondering if it will work on win 7 because i don't want to change my OS anytime soon.
IamMike
68
ok the best info i could gather about the cards trough Alternate.be website (idk if there are accurate or not)
but there seem to be huge differences here and there (still don't know wich i should pick).
There is difference in Price , BaseClock / Boost Clock ,RAM Speed, OS Support apparently idk , MAX Resolution , And Waranty time, And power consumption but that i don't realy care.
XFX XFX AMD Radeon VII 16GB HBM2 grafische kaart € 779
Type
Grafische kaart
EAN
0778656077331
Fabrikantcode
RX-VEGMA3FD6
Aansluiting
PCIe x16 Versie 3.0
Bezette sloten
Grafische chip
Naam
AMD Radeon VII
GPU Serie
AMD Radeon VII
Klokfrequentie
1750 MHz
Boostfrequentie
1801 MHz
Stream processoren
3840
DirectX versie
DirectX 12, OpenGL 4.5
Geheugen
Beschikbaar
16 GB (HBM2)
Geheugen interface
4096 bit
Geheugensnelheid (effectief)
1 GHz
Aansluitingen
1x HDMI, 3x DisplayPort
Stroomverzorging
Stroomverbruik
375 W
Aansluitingen
2x 8-pins (6+2) aansluiting
Minimale voeding
min. 750 W
Koeling
Koeling met ventilator
Bijzonderheden
VR-Ready
Ja
High-End kaart
Ja
Besturingssysteem
Ondersteund
Windows 10
Afmetingen
Breedte: 125 mm x Hoogte: 40 mm x Diepte/lengte: 280 mm
Garantie
24 maanden
MSI Radeon VII 16G grafische kaart
799
Type
Grafische kaart
EAN
4719072625016
Fabrikantcode
V803-897
Aansluiting
PCIe x16 Versie 3.0
Bezette sloten
Grafische chip
Naam
Radeon VII
GPU Serie
AMD Radeon VII
Klokfrequentie
1400 MHz
Boostfrequentie
1750 MHz
Stream processoren
3840
Kenmerken
Radeon FreeSync, Radeon FreeSync 2 HDR, Vulkan
DirectX versie
Geheugen
Beschikbaar
16 GB (HBM2)
Geheugen interface
4096 bit
2 GHz
Aansluitingen
1x HDMI Versie 2.0, 3x DisplayPort Versie 1.4
Multi-GPU technologie
Crossfire ready
Stroomverzorging
Stroomverbruik
300 W
Aansluitingen
Minimale voeding
min. 650 W
Koeling
Bijzonderheden
VR-Ready
Ja
High-End kaart
Ja
Kenmerken
Ondersteund max. 4 monitoren tot een resolutie van max. 7680x4320
Afmetingen
Breedte: 121 mm x Hoogte: 40 mm x Diepte/lengte: 267 mm
Gewicht
1,3 kg
Garantie
36 maanden
Garantietoevoeging
Let op: het gebruiken van dit product voor doeleinden waar dit niet primair voor is bedoeld, kan buitengewone slijtage tot gevolg hebben. Hierdoor kunnen eventuele aanspraken op garantie komen te vervallen.
SAPPHIRE Sapphire RADEON VII 16G HBM2 grafische kaart
819
Type
Grafische kaart
EAN
4895106286931
Fabrikantcode
21291-01-40G
Aansluiting
PCIe x16 Versie 3.0
Bezette sloten
Grafische chip
Naam
AMD Radeon VII
GPU Serie
AMD Radeon VII
Klokfrequentie
1400 MHz
Boostfrequentie
1750 MHz
Stream processoren
3840
DirectX versie
Geheugen
Beschikbaar
16 GB (HBM2)
Geheugen interface
4096 bit
1 GHz
Aansluitingen
Stroomverzorging
Stroomverbruik
250 W
Aansluitingen
Minimale voeding
min. 750 W
Koeling
Bijzonderheden
VR-Ready
Ja
High-End kaart
Ja
Besturingssysteem
Ondersteund
Windows 10
Afmetingen
Breedte: 120 mm x Hoogte: 42 mm x Diepte/lengte: 268 mm
Garantie
36 maanden
ASRock Phantom Gaming X Radeon VII 16G grafische kaart
799
Type
Grafische kaart
EAN
4717677338119
Fabrikantcode
90-GA1100-00UANW
Aansluiting
PCIe x16 Versie 3.0
Bezette sloten
Grafische chip
Naam
AMD Radeon VII
GPU Serie
AMD Radeon VII
Klokfrequentie
1400 MHz
Boostfrequentie
1750 MHz
Stream processoren
3840
Kenmerken
FreeSync2 Technology, AMD FreeSync2 HDR, Radeon VR ready Premium, Radeon Relive, Radeon Wattman
DirectX versie
Geheugen
Beschikbaar
16 GB (HBM2)
Geheugen interface
4096 bit
2 GHz
Aansluitingen
1x HDMI Versie 2.0b, 3x DisplayPort Versie 1.4
Stroomverzorging
Stroomverbruik
300 W
Aansluitingen
Minimale voeding
min. 650 W
Koeling
Opmerking
Tripple fan cooling, Backplate
Bijzonderheden
VR-Ready
Ja
High-End kaart
Ja
Besturingssysteem
Ondersteund
Windows 7, Windows 10
Opmerking
Maximale digitale resolutie: 5120x2880
Afmetingen
Garantie
36 maanden
IamMike
68
Just one question, i have 2 x s27c350 Samsung screens (idk if it's with freesync) but do i need freesync monitors? Or can i just buy the card and it will work?
Thx.
IamMike
68
I have to say, it is a beast!
i can work now without having to fear my apps will crash because of running low on VRAM.
I can just keep opening 3D meshes inside Ue4 with no lag at all.
For games i can upscale resolution to max , other settings all on ulta with a stable 60fps +.
I didn't test a lot of games as i have not so much time for it but i tested BF4 max upscaled all on ultra,
on a few server with 64 players, i occasionaly have frame drops , but i guess it's normal for big servers,
other then that i have steady 60 fps.
On Assassins creed Odysey, i had more frame drops that i tought i would have,
but then again, it's a big open world.
I first tought it would bottleneck a lot with my FX 8350 at def 4.0 ghz, but i'm surprised that i'm in fact not.
Games i usualy had to OC my CPU for up to 4.6, i don't have to OC anymore, it runs fine on 4.0 ghz.
I can say i had lot of trouble figuring out why my pc would freeze when i had a power outage,
but i found out the Wattman software sucks.
It would restore my settings to default and as result my pc would completely freeze but i found the solution to it. Just don't use it.
For all the reviews about the fans being to loud ...
i have to say i have no problem at all, the card is quiet !
I even dind't have to undervolt it and adjust fan curve!
Maybe it's brand differences idk.
I bought the AsRock Phantom Gaming X Radeon VII because i found it at a better deal then Powercolor or XFX.
Cheers!
