I'm new to Liquid cooling so I decided to buy one of the NZXT X31 kits.
I won't be overclocking and will be running my system at stock speeds (its a Xeon).
My current problem is, that my stock dell chasis doesnt have the best ventilation and the heat from the GPU often heats up the stock heatsink and causes the fans to ramp up.
I tried the Cooler master EVO, but it was too tall for the side panel to close. I was thinking of the low profile heatsinks, but they require me to install a custom backplate. In my case the Dell motherboard alreayd comes with threaded mountings for the heat sink (Which I'm assuming will hold the liquid cooling block, i might need to make a run to home depot to get some other screws that will match, instead of the standoffs)
So I thought I might give the X31 a shot.
My question, is has anyone ever done something like this on a OEM motherboard? Anything I should look out for?
Also, with liquid coolers, in case if something fails, is there any monitoring software that I could use to shut the computer down? ( I'm assuming Dell's bios has something built in, but just to feel safe I wanted my PC to shutdown if the temperature ever reaches 80degrees, instead of the usual 90+)
By the way, I have a 1150 socket Xeon 1225v3 processor and Dell T20 Server chasis
Also, any good/bad experiences with the X31 over the Corsair H80i ?
