Any graphics card will not work in motherboard
kaditrix
Motherboard is a gigabyte B250M-DS3H graphics card test 1: GTX 1060 3gb OC PNY graphics card test 2: GTX 6?? processor: Intel Core i5-7600K ram: 16gb ddr4 2400 megahertz PSU: 600 watt
Both graphics cards do not work. I cannot install drivers because Nvidia says i don't have a Geforce graphics card installed. Bios is up to date. EDIT: Computer turns on, fan and lights on GPU turn on.
Last time I've seen this there were bent pins in the socket under the CPU, time before that the PCIe POWER connector from the PSU was actually not putting out any power. Any chance you could check that slot with some other random unpowered PCIe adapter? maybe an old network or sound card or something.
The random gtx 6?? that i found does not need power from the PSU. Not sure if that is what your asking i should do or not. First time pc builder 😛
