Any objections? Will it all work ok? First build
You have an amd cpu and an Intel based motherboard.. you either need to switch mainboard, or switch Cpu.. personally I would prefer cas 7 ddr3 1600 ram instead of cas 9. but that is personal preference.. I would get the 660ti over the 660 even th OC edition ( but that's me )
I'd personally recommend getting the Intel i3-3225 or the i5-3470 and then you can downgrade your motherboard to an Intel H77. If you post your budget that will help to suggest parts.
Not true.
Try this:
CPU: Intel Core i5-3470 3.2GHz Quad-Core Processor ($149.99 @ Microcenter)
Motherboard: ASRock H77 Pro4/MVP ATX LGA1155 Motherboard ($87.55 @ Newegg)
Memory: Mushkin Blackline 8GB (2 x 4GB) DDR3-1600 Memory ($35.57 @ NCIX US)
Storage: Western Digital Caviar Blue 500GB 3.5" 7200RPM Internal Hard Drive ($59.98 @ Outlet PC)
Video Card: Sapphire Radeon HD 7870 GHz Edition 2GB Video Card ($251.97 @ Newegg)
Case: Cooler Master HAF 912 ATX Mid Tower Case ($49.99 @ NCIX US)
Power Supply: SeaSonic S12II 620W 80 PLUS Bronze Certified ATX12V / EPS12V Power Supply ($79.99 @ Newegg)
Optical Drive: Lite-On iHAS124-04 DVD/CD Writer ($17.89 @ Outlet PC)
Total: $732.93
(Generated by PCPartPicker 2012-12-25 23:49 EST-0500)
Quad core Intel + Radeon 7870 and it's just barely over the $700 limit.
