Any of these parts not belong with the rest?
rhnoble
This is my first build so I figured I'd see if these parts make sense. I'm using it for coding mostly, and a little bit of gaming. I was told not to be cheap about the PSU and I want it to be able to handle anything I add on later, but is this one totally overkill? Also does anyone have thoughts on whether I should wait until Zambezi comes out before I buy the Phenom, in case there are price drops? I also don't have a case picked out yet, so I'm taking comments on that too.
Phenom II X4 955
GIGABYTE GA-970A-UD3 Motherboard
MSI R6850 Cyclone PE Radeon HD 6850
Team Elite 8GB (2 x 4GB) 240-Pin DDR3 SDRAM DDR3 1333
PC Power and Cooling Silencer 910W
Crucial M4 CT064M4SSD2 2.5" 64GB SATA III MLC Internal Solid State Drive
cutebeans
Since you don't have a Case and Optical drive yet
http://www.newegg.com/Product/ComboDealDetails.aspx?ItemList=Combo.743728
get this, it's a pretty good case and with the combo you save $10 bucks.
Get this, CPU + GPU combo. Same price but better GPU than you have now.
http://www.newegg.com/Product/ComboDealDetails.aspx?ItemList=Combo.748583
Get this PSU + HDD since you don't have one
http://www.newegg.com/Product/ComboDealDetails.aspx?ItemList=Combo.743513
If you already have an HDD, get this PSU + Ram combo, better than yours.
http://www.newegg.com/Product/ComboDealDetails.aspx?ItemList=Combo.745021
rhnoble
Approximate Purchase Date: ASAP
Budget Range: Definitely under 1000 preferably around 700
System Usage from Most to Least Important: Mostly coding, some gaming, general internet stuff
Parts Not Required: Have the keyboard, mouse, monitor, speakers
Preferred Website(s) for Parts: I've got a cart filled on newegg, but I'm not opposed to finding better prices elsewhere.
Country of Origin: USofA
Overclocking: Would like to give it a try
SLI or Crossfire: Maybe some day
Monitor Resolution: 1280 x 1024
Additional Comments: Mostly looking for something to last me a while that I can upgrade easily.
Sorry, don't know how I missed the form the first time around.
cutebeans
Just check the recommendations I already said. :)
You also need an HDD. Get the first 3 recommendations and post again what you have changed to your build.
