Any parts to swap or is the build solid and ready to order?
Mack244
22
I got my first gaming pc build made for video editing/rendering, streaming, gaming (of course). I tried to pick out the best parts that go together. I will be overclocking this system to see the true power within, that's why I went with the H100i liquid cooling for low temps instead of the cool master 212 fans. I know that almost everything is A1, for example I got the intel i7 4790k 4.0ghz in order to overclock it and achieve the fastest speeds in games and rendering. The only thing I'm not sure about is the wireless card, and if I'm going to need one or not. I have the asus one picked, but I want to know if usb is better than PCI adapters. Anyways it would be greatful if you could give me some insight on wireless cards, cause I'm a scrub when it comes to that.
http://pcpartpicker.com/p/mFRPgs
Btw I have a $1700 max max max budget
Dear,
Great build.
If you are into video editing/rendering then you should consider buying 16 gigs RAM. Also you don't need thermal compound. Rest your selection of components is excellent.
