Any problems with my computer build?
jhammond
4
Heyy, this is the computer i built on centre.com and i was just curious if everything will fit in the case and that everything will work well, like the cpu isnt capable with the mother board or something, thank you or maybe if ive missed something :)
Specs:
Intel i5-4460 3.2GHz (3.4GHz Turbo) 4 Cores 6MB Cache LGA1150 CPU *Intel Promotion*
Asus Z97-K ATX Intel 1150 Motherboard
G.Skill DDR3 8GB (2x4GB) PC3-14900 1866MHz Ares Desktop RAM
Seagate 2TB Barracuda 3.5" Internal Hard Drive ST2000DM001
NZXT H440 Mid-Tower Case Matte Black/Green
21.5" Samsung S22D300H 21.5" Wide (16:9) LED, 1920x1080, 5MS, DSUB, HDMI
UPDATE:
so ive changed afew things but i dont know if i need/should get afew things. does it matter what Network adapter i get? what sound cards to get? card readers? windows 7 or 8?
And these are the specs i have now:
ASRock H97M Pro4 LGA 1150 Motherboard
TP-Link TL-WN881ND 300Mbps Wireless N PCI Express Adapter
Gigabyte GeForce GT 740 2GB GDDR3 Graphics Card
Asus Xonar DGX PCI Express 5.1-channel Gaming Audio Card
Windows 7 Professional OEM 64BIT Service Pack 1
jhammond
4
i do have ram i forgot to put that in, im getting 2
i dont like windows 8, does it make things run better?
what do you suggest i do about the hard drive, motherboard, graphics card and audio car?
and the case comes with fans and a power supply
jhammond
4
So idk what to do so im just going to buy an already made computer, thank you for your help but i have a budget of 1500, and it seem i cant make a good computer for that much
