Any problems with this build?
Haopeng Lin
36
http://pcpartpicker.com/p/HKgBwP
I have an i7-4770 @ 3.4 in my old PC and plan on moving it over to this PC when I buy all the parts.
Is there any problems you see in this build?
I picked the MSI R9 390 over the GTX 970. (Apparently has better performance..?)
Is there anything else I would need to buy for the computer outside of this? (I already have Thermal Paste)
PCPartPicker part list: http://pcpartpicker.com/p/3gMVJx
Price breakdown by merchant: http://pcpartpicker.com/p/3gMVJx/by_merchant/
CPU: Intel Core i7-4770 3.4GHz Quad-Core Processor ($299.99 @ SuperBiiz)
CPU Cooler: Cooler Master Hyper 212 EVO 82.9 CFM Sleeve Bearing CPU Cooler ($24.88 @ OutletPC)
Motherboard: ASRock H97M PRO4 Micro ATX LGA1150 Motherboard ($79.89 @ OutletPC)
Memory: Crucial Ballistix Sport 16GB (2 x 8GB) DDR3-1600 Memory ($64.99 @ Amazon)
Storage: Samsung 850 EVO-Series 250GB 2.5" Solid State Drive ($84.98 @ OutletPC)
Video Card: PowerColor Radeon R9 390 8GB PCS+ Video Card ($279.99 @ Newegg)
Case: Corsair Vengeance C70 (Black) ATX Mid Tower Case ($109.99 @ Amazon)
Power Supply: XFX TS 750W 80+ Gold...
Yes.
You are paying more than necessary in motherboard and especially in the PSU.
A z97 chipset is only useful if processor can be overclocked, when it is a locked one ( like yours) a good H97 board is plenty for it.
For PSU, an EVGA G2 750W, which is currently one of the best PSUs out there is there for less than the PSU listed in the build.
http://pcpartpicker.com/part/evga-power-supply-220g20750xr
A good 650w is enough for this build though.
Edit : IF EVGA PSU is not available at your location and price of corsair 760 is different and acceptable by you, you can buy it.
While yes this is a very solid build in itself you can save yourself a little bit of money by changing a couple of things around, also yes the R9 390 is better than the GTX 970 but it doesn't really shine until you go to 1440p or 144Mhz otherwise its kind of going to waste a little bit. Also there are new GPU coming out in the next couple of months so it maybe worth holding back a bit of money and getting a new GPU when they come out? maybe only use a GTX 960 for now which is still a good gpu and then buy a new GTX 1070 when it comes out. below is a build with a GTX 970 because I assume you are not on 1440p or 144Mhz yet.
Motherboard: ASRock H97M-ITX/AC Mini ITX LGA1150 Motherboard ($89.99 @ SuperBiiz)
Memory: G.Skill Ripjaws X Series 16GB (2 x 8GB) DDR3-1600 Memory ($68.89 @ OutletPC)
Video Card: Gigabyte GeForce GTX 970 4GB Video Card ($307.49 @ Newegg)
Power Supply: XFX Core Edition 750W 80+ Bronze Certified ATX Power Supply ($52.00 @ Newegg)
Total: $1038.21
Generated by PCPartPicker 2016-01-28 06:30 EST-0500
Power Supply: XFX TS 750W 80+ Gold Certified ATX Power Supply ($69.99 @ Newegg)
Total: $1014.70
Generated by PCPartPicker 2016-01-28 07:11 EST-0500
