Hey all I am in the process of a new build and am looking to get a solid PSU and looking to future proof a bit hence the ATX 3.0 for a future 40 series GPU. Thanks all and cheers!
This is amazing feedback! Thank you so much for you time and input. The PC community has been very helpful and kind. I really appreciate it, thanks again.HotCheeZe82 Good morning. With the exception of the MSI models below, here are some of my favorites. I have no experience with any ATX 3.0 / PCIe 5.0 PSUs, as the standard is very new. The MSI 850 watt model only has six customer ratings on NewEgg, and some are very negative. But since there are only six, therefore I can't even guess the validity of the overall reviews. But it's reasonable price, so I figured that I would present the listing and let you make up your own mind. Personally I'd feel more comfortalbe with the Seasonic if I was going with the new standard, however they appear to be very pricey at the moment. I assume that the prices will lower once Amazon has stock of them, and all models are fully available across both NewEgg and Amazon. So if you're considering purchasing these, it might be worth waiting until inventory normalizes in perhaps February.
The Super Flower are some of the best PSUs in the world, if you don't mind not having the new 16 pin connector. Since they don't have a US tech support team, all warranty support is done through Amazon or NewEgg customer support (whomever you purchase from). EVGA T2 1000 is the same model line of Super Flower, but you get to deal with the excellent EVGA support team in the US, if you ever have a warranty issue. Also, the EVGA variant has all sleeved cables, wheras the Super Flower OEM model comes with non-sleeved flat ribbon cables, and more aggressive fan curve (from what I've read in performance and customer reviews). I personally have the EVGA T2 1000 in my main rig, but purchased it years ago on NewEgg for a one day 50% off sale. My two other family member rigs have the EVGA P2 850, which is no longer available, but the Super Flower Platinum 850W (available) is what those P2 850s are based off of.
The Corsair RM850x is a reasonably priced tried-and-true model; I just this month purchased one for a friend of mine. The Corsair HX1000i series is interesting because you can connect it to your motherboard via an internal USB header and pull real time analytics data, such as wattage consumption, and efficiency.
I have to admit that I'm recently torn between purchasing a new ATX 3.0 / PCIe 5.0 PSU (new standard but little reliability history) or a tried-and-true standard power supply (older standard without 16 pin connector, but established reliability history).
ATX 3.0 / PCIe 5.0 - with new 16 pin (12 pin + 4 sense pins) 600W connector for RTX 40 series (without using four 8 pin to one 16 pin adapter included with 40 series GPU)
($160 - $200) price range
MSI MPG A850G PCIE5 850 W
$159.99
* poor customer reviews on newegg, but only 6 reviews / gold power efficiency
https://www.newegg.com/msi-mpg-a850g-pcie5-850-w/p/N82E16817701017
MSI MPG A1000G PCIE 5.0 1000W
$199.99
https://www.newegg.com/msi-mpg-a1000g-pcie-5/p/N82E16817701016
($220 - $290) price range
Seasonic VERTEX GX-850, 850W 80+ Gold, ATX 3.0 / PCIe 5.0
$219.99 (out of stock)
* gold power efficiency (platinum estimated arrival in February)
https://www.newegg.com/seasonic-vertex-gx-850-850-w/p/N82E16817151258
Seasonic VERTEX GX-1000, 1000W 80+ Gold, ATX 3.0 / PCIe 5.0
$249.99 (Back order available ETA Date: 1/31/2023)
https://www.newegg.com/seasonic-vertex-gx-1000/p/N82E16817320022
Seasonic VERTEX GX-1200, 1200W 80+ Gold, ATX 3.0 / PCIe 5.0
$289.99
https://www.newegg.com/seasonic-vertex-gx-1200/p/N82E16817320023
Traditional power supply without 16 pin connector 600W connector
($135) price
Corsair RM850x(2021) 850W
$134.99
$149.99 (+ $15 off w/ promo code MKTCNA726)
*platinum power efficiency
https://www.newegg.com/super-flower-leadex-platinum-sf-850f14mp-850w/p/1HU-024C-00036
($200 - $280) price range
Super Flower Leadex Titanium 1000W
$229.99 (+ $30 off w/ promo code MKTCNA724)
* titanium power efficiency
https://www.newegg.com/super-flower-leadex-titanium-sf-1000f14ht-1000w/p/1HU-024C-00012
Corsair HX1000i 1000W
$259.99
* platinum power efficiency / With CORSAIR iCUE Software, you can monitor your power supply performance, toggle single rail or multi rail mode, and control fan speed directly from your desktop.
https://www.amazon.com/Corsair-HX1000i-Platinum-Ultra-Low-Connectors/dp/B0B3S8HR8M
EVGA SuperNOVA 1000 T2 1000W (Super Flower OEM) (This is the EVGA version of the Super Flower Leadex Titanium 1000W)
$279.99
https://www.amazon.com/EVGA-Supernova-Titanium-Warranty-220-T2-1000-X1/dp/B018JYHGQE
I havent purchased anything yet but i am going to go with the Seasonic VERTEX GX-1200, 1200W 80+ Gold. They should be back in stock by the end of the month. Im looking forward to completing the build and should hopefully be up and running in February. Thanks again for the input as it was very helpful.Any update? Have you settled on a purchase?
By the way, here is one more 1200W non-ATX 3.0 / PCIe 5.0 PSU, but it's still an excellent option, and $45 cheaper than the 1600 watt model that I previously mentioned. Also, it'll be noticeably lighter than the 16000W variant.
Super Flower Leadex Platinum SE 1200W 80+ Platinum
$209.99 (+ $15 off w/ promo code MKTCNA727, limited offer By Super Flower)
https://www.newegg.com/super-flower-leadex-platinum-se-sf-1200f14mp-v2-1200w/p/1HU-024C-00037
https://www.super-flower.com.tw/en/products/leadex-platinum-se-1200w
