Question Any Recommendation For a Full-Size Cooler Small Case?
Regev
290
18
10,685
Hi,
I'm building a gaming machine (probably with strongest AMD CPU & strongest AMD GPU), I want it small. As small and light as it could be, cause I'll be moving it frequently between my OLED gaming TV to run games better than the PS5 can, and onto my desk monitor to play games like Football Manager or RTSs. Case needs to be as small and as light as possible, with clearance for a full-size dual tower cooler like the Phantom Spirit or Frost Spirit, and fit a GPU like the 9070 XT. Ideally, I'd like it to be small like an Xbox Series X, but I know that's a stretch because AMD manufactures the chips specifically for the console makers custom sizes.
Thanks!
Why not keep the PC at your desk and plug TV behind the PC as 2nd monitor? All you need, is long enough display cable to reach from TV to the PC. And once you start gaming on TV, just enable TV as 2nd or primary monitor.
For a PC case, Thermaltake The Tower 250 would be one option. Comes in many color flavors,
lineup: https://www.thermaltake.com/products/chassis.html?cat=77&chassis_series=51
Also, has up to 210mm CPU cooler clearance (meaning any air cooler will fit + then some) and has GPU clearance up to 245mm (or 360mm when removing PSU shroud).
Only mini-ITX MoBo fits into it. So, the case is small. SFX PSU is standard option, but it can house ATX PSU as well. And it has nice eyecandy too.
The smaller the PC case - the higher the component temperatures will be (due to lesser fans and smaller air volume inside the case).
The beefier the hardware - the higher the temperatures will be (due to consuming more power).
So, you can't make it as small and as powerful as be. Well, you can, but thermal throttle is then given. And that even to the point of all fans at 100% may not be enough to cool that hotbox. Not to mention the noise you'll then hear.
With this, i advise to get a bit bigger PC case than the smallest possible, like The Tower 250.
But if you want the smallest PC case, further reading: https://pcpartpicker.com/forums/topic/55093-list-of-cases-for-steam-machinebox
Note: that list is outdated and availability of those PC cases may be the issue. Not to mention the clearance validation one-by-one from specs page.
But when building small mini-ITX system, idea is that you 1st buy the PC case and then the components that fit into it. Rather than getting components and then trying to find suitable PC case for them.
Another option in terms of lightweight PC case (not small, but weighs less), is going with open-air PC case.
E.g Tt Core P3,
specs: https://www.thermaltake.com/core-p3.html
amazon: https://www.amazon.com/dp/B07BFGB8Z6?th=1
With this, you have ample clearances, up to 180mm CPU cooler and up to 450mm GPU. While it can house ATX MoBo and ATX PSU. But since PC case has as little metal as possible, it doesn't weigh that much either. And cooling is also good since entire room's air acts as one big heatsink for the PC. Compared to closed PC case, where only the air inside the PC case acts as a heatsink.
Reactions: Regev
Hi,
Thanks!
Couldn’t you just run a 15m HDMI cable to the TV?
@Aeacus , thanks for the tips.
I'm using the TV as a general-purpose TV for the house as well (it's a Samsung S95B), only gaming at the evenings. Currently I got 2x 32" 2K IPSs side by side in the office, where I work from. The idea was to build the computer to function as my office during the day (running Fedora on one partition) and then BazziteOS for gaming on another partition for when I want to take it to the living room and play on the TV, or just use the office setup for RTSs or Football Manager.
I thought of just wall-mounting that Thermaltake P3 Core next to the TV in the living room, and keep my current PC at the office (it's a 14900K@180W on a tiny MiniITX and FlexPSU custom build case), Then if I ever want to play RTSs or Football Manager, I can Steam Remote Play from the stronger computer straight to my tiny office PC. These games don't need super low latency anyway.
But if I can get a case small enough to carry, and efficient enough to cool (like the vertical Xbox), it could be a nice compromise.
@LordVile , it's more like 35m away, multiple rooms in-between.
This would be what i do, since lugging around entire PC (no matter how small), will get annoying, fast. Because besides carrying it, you need to unhook all cables coming to it and connect them all again when you're at TV.
Also, all connectors have finite amount of unplug/plug instances to them. Display cables (HDMI/DP) and power cable (IEC C13/14) have them at much lower than e.g USB, because those cables aren't designed to be constantly unplug/plug as USB is. And even USB connector will wear out eventually (either the connection is loose or doesn't make a connection anymore).
Oh, trip when you are carrying your PC and say goodbye to it. PC will not survive a fall from ~1m height. Heck, even laptop, which is designed to be portable, doesn't do well with falls.
Reactions: Regev
Do you own a drill? You can route cables through walls and floors.
Guys, thank you all so much. I think what I'm going to do is mount the computer on the wall (open air case) in the air conditioning compressor niche (it's exposed to the outside temps, but protected from rain), and then run thunderbolt cables through the walls, and connect them to thunderbolt hubs, each connected to the monitor/TV and all peripherals.
I love the idea, because it eliminates the computer from view (more space, toddler-friendly, and zero fan noise even if 100% spinning). My only issue, how much will latency increase, say, with 50m thunderbolt cables?
Oh, and these statements are irrelevant.
I disagree with this statement.
You're not accounting for varying airflow or open-loop configurations.
You may disagree with me, but for mini-ITX builds, you can't go with open-loop cooling because case is small and it doesn't have enough space for a rad, let alone for tubing and reservoir.
Prime example would be this StarForge prebuilt mini-ITX build (which is one of the better prebuilts one can buy);
Review:
View: https://www.youtube.com/watch?v=yI_SN7cpTas
To where you put the open-loop in that? 🙄
Others may also disagree with you.
The OP never mentioned mini-ITX, you did.
OP clearly said;
And that either means: pico-PC, mini-PC or mini-ITX build. Pico- and mini-PCs doesn't have powerful specs, leaving mini-ITX build as only option.
That YT page you linked, they used the same Fractal Design Terra PC case as StarFroge prebuilt did.
View: https://www.youtube.com/watch?v=l34iX2Li4io
And where the rad and reservoir are? 🙄
They are outside of the Terra case, since those doesn't fit inside the case. Heck, the rad/reservoir unit is actually bigger than the Terra itself is.
Review:
What? I have a full loop with 2x 240mm rads in my mITX, very similar to what Optimus Tech did right after, several years ago.
The Bigger the case, the harder it is to cool over extended periods because larger cases tend not to have sufficient exchange of air.
2x 120mm fans at 50cfm will fully exchange air in a 6Ltr mITX case in seconds. 4x 120mm fans at 50cfm will take minutes to fully exchange the air in a standard ATX at 40Ltr.
Reactions: williamjeremiah
And where the reservoir is?
I see it being outside of the PC case.
Idea of proper build is to have everything fit inside the PC case. Not some inside and some outside.
This is only true when you have empty PC case without any restrictions inside the case (like MoBo, GPU, PSU).
Mini-ITX builds are cramped tight, where airflow in them is very restricted, if not completely blocked off. So, even when you run fans at full tilt, there still would be hot air pockets where airflow can not exchange.
So, for mini-ITX builds, where you can install 2-3x 80/120mm fans, you need to keep the fans running at higher RPMs, just achieve enough static pressure for proper cooling (due to internal restrictions). And higher fan RPM = more noise.
In my full-tower ATX case, i have ample space to install many fans and since i don't have airflow restrictions in my PC as mini-ITX build has, i can run my fans, which are 140mm, at lower RPM, making virtually silent build, while still having ample cooling for my components.
