Question Any way to fix tearing under VRR range?
Mar 24, 2021
16
My monitor's VRR/Gsync compatible range is 60-240, so occasionally it dips under 60 in Valhalla, I get some tearing. Besides V-sync, is there something I can do through Nvidia Control Panel to mitigate this?
I'm usually getting 80-90, but just this one area has a lot of stuff going on. Some games have a setting that wont' let you go under a certain gps, it was automatically change resolution on the fly, that's useful, but i've never used it.
Thank you!
Yea, that would be helpful above the refresh rate, like when I used to have a 60hz monitor and I was getting 80fps, Fast sync helped, but now I have a 240hz monitor and VRR goes from 60-240. I rarely go under 60, but I must admit it is annoying when I do. VRR range should go down to 40.
