i have been browsing for a long time now and have had no luck with a diagnosis.
iv had a rig since 2011, upgraded almost all parts at this point, mobo, gpu, HDD/SSD, ram, CPU and a few others. back in February i did a clean install of the OS that didnt help much or made the issues worse. also i have uninstalled every driver and windows update i can and reinstalled from factory or driver website including beta versions and older versions.
iv had several BSOD with multiple errors codes. occasionally during BS it will have an annoying buzzing sound. sometimes when it reboots it goes to onboard graphics (crappy res, no dual monitor just mirrors) and when i go into device manager the video card is shown as not working. i disable the device then enable and it works just fine. i tried a few BSOD reporting tools in the past and posted in a different forum for BSOD and got no solid info except for clean install, update drivers, check ram. also used a monitor to track power consumption and no irregularities.
hard to remember what they all the BSOD codes are but a common "fix" that i keep seeing for most of them is: update video drivers, clean install, check ram. i have run every check i can find on the ram and have even swapped them and they all work or dont cause more issues at least. clean OS install (painful) and redone every driver i can.
is there any way to test the GPU if its faulty? (even though it works most of the time even with FO4, Skyrim, HTV Vive with no issues) the BSODs happen at completely random times. nothing makes it worse, browsing in MS Edge/chrome, playing VR games, LoL, FO4, or just writing in MS Word. nothing i do makes it worse or better and it can happen either in 20 minutes or a week.
setup:
Win 10 build 17134.228
ASUS M5A99FX Pro R2.0 AMD 990FX
AMD FX-9370-NOT OC
R9 Fury X-NOT OC
G.SKILL TridentX Series 32GB (4 x 8GB) DDR3 2133 (PC3 17000)
1000W PSU (only thing i havent needed to r2 (replace) still works great.
massive airflow with the case, antec df-85. only ever had a minor CPU overheat problem with Mass Effect Andromeda but dropped a few CPU cores when i played it and it ran fine. never seen the GPU go over 55 degrees i think. CPU has hit 60 a few times and froze but only on MEA until i dropped cores. issue started before that though.
any help would be appreciated. its VERY aggravating to start an online game to just BSOD (though SSd boot time helps) before my upgrade of the MOBO, CPU, GPU, RAM, there was no issue.
setup:
AMD FX-9370-NOT OC
R9 Fury X-NOT OC
