Anybody help with Roccat XTD settings?
Deathgrins
21
I was going to ask this question to Roccat support but ever since I installed my mouse driver I can no longer access there website.
I was wondering if there was a way to change the key binding of each button on the mouse,
I was playing insurgency and I wanted to set my front side button to change firing mode then use easy shift right click for toggling crouch but, when I try doing this it registers them both as MOUSE 5 which kind of makes using the easy shift useless and puts me down a few buttons. also pushing the scroll wheel left and right for some are both registered as alt.
Can I change it to register as num 1, num2 or mouse 6 and mouse 7?
http://www.roccat.org/Support/Gaming-Mice/ROCCAT-Kone-XTD/
has the drivers you are looking for.
if for windows this is the direct XTD driver download http://www.roccat.org/file_driver_789_280dfd954a1620e6710cbfb1b7448fa8
the roccat software allows you to map different commands. see the photo below
index.php
however, it is often easier to change your in game key mapping commands, provided each of the mouse buttons has a unique mouse1, mouse2, etc number and two arent set up duplicate (which is the case sometimes)
the software should allow you to specify any key for the buttons however you definitely dont want to touch the left and right click button keys. any of the extra...
index.php
the software should allow you to specify any key for the buttons however you definitely dont want to touch the left and right click button keys. any of the extra buttons it doesnt matter (i've had my side buttons on a different mouse mapped to the "A" key for instanance). some software even support macros and it looks like the roccat software does. you should be able to create a new macro to do what you want.
